Guest Guest_Mark_* Posted July 22, 2004 Posted July 22, 2004 Hi I have been asked by a client to look at a scantronic 9600 keypad . The problem is that if you press any key nothing happens ,apart from a bleep. The keypad appears to have locked . The day date and time are visible . The problem started after a builder removed 2 contacts on a door without telling the owner of the property . I do not know if the two are connected but any advice would be most welcome. Thanks Mark
norman Posted July 22, 2004 Posted July 22, 2004 hi Marks, it sounds like it has locked out on tamper, try repowering and entering the code that should sort it, then you will have to repair the cable fault. Nothing is foolproof to a sufficiently talented fool.
Guest S&K SYSTEMS Posted July 22, 2004 Posted July 22, 2004 Hi mark key pad is normally wired up using 4 core but you only need 3cores back to the control panel make sure the signal wire is ok from the control panel to the key pad any error messages the builder might have damaged a cable if no joy reset the nvm if you know how if not pm me
breff Posted July 22, 2004 Posted July 22, 2004 I've also had a keypad lock up in the past, try removing and reapplying 12v at the keypad. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest Guest Posted July 24, 2004 Posted July 24, 2004 hi Marks,it sounds like it has locked out on tamper, try repowering and entering the code that should sort it, then you will have to repair the cable fault. 18121[/snapback] Thanks for that , regards mark
norman Posted July 24, 2004 Posted July 24, 2004 Pleased we could help. Nothing is foolproof to a sufficiently talented fool.
Guest guest Posted August 7, 2004 Posted August 7, 2004 Hi I have been asked by a client to look at a scantronic 9600 keypad . The problem is that if you press any key nothing happens ,apart from a bleep. The keypad appears to have locked . The day date and time are visible . The problem started after a builder removed 2 contacts on a door without telling the owner of the property . I do not know if the two are connected but any advice would be most welcome. Thanks Try taking the panel cover off then putting it back on then enter 99 this should clear it if not measure the resistance between the cable if faulty replace and then try. Mark 18118[/snapback]
norman Posted August 7, 2004 Posted August 7, 2004 ? Nothing is foolproof to a sufficiently talented fool.
