Guest GCG Posted July 22, 2004 Posted July 22, 2004 Hello everybody! What else do I need to do beyond setting Section [352] with A2, A1, 00 Section [370] with 003, 003, 003, 000, 030, 003, 007, 030, 007, 030 Section [371] with 0800 to program a Periodic Test Transmission (weekly at 8:00 am using the land line) to the Monitoring Station? Thanks in advance for your help. Gilbert
j.paul Posted July 22, 2004 Posted July 22, 2004 Section 301 (phone no) Section 303 (backup phone no) Section 310 (chip no) don't need Section 352, just make sure Section 381 (option 3 off) Section 360 with 04,04 Section [370] with 003, 003, 003, 000, 030, 003, 007, 030, 007, 030 Section [371] with 0800 Section 380 (option 1 on) Make sure Monitoring Station can receive SIA Hope this helps jpaul There are no stupid questions, but there are a LOT of inquisitive idiots.
Guest GCG Posted July 23, 2004 Posted July 23, 2004 Thanks, jpaul! I'm going to give this a try and I'll let you know what happens
Guest GCG Posted July 26, 2004 Posted July 26, 2004 ...don't need Section 352, just make sure Section 381 (option 3 off)Make sure Monitoring Station can receive SIA... 18159[/snapback] Thanks again for your help. It sure is the guidance I need! Just a quick note before I give you the follow up: my Monitoring Station receives Contact ID and Section 381-Option 7 is ON. I did all you told me, but still no luck with the Periodic Test Transmission. Then I tried to perform a User System Test with [*][6][Master Code][4] that among other things is supposed to test the bell output and send a system test reporting code to the station, but nothing happened either: no bell sound and no call. I guess I'm missing some settings that need to be programmed. Could you please give me a hand on this? Regards, Gilbert
j.paul Posted July 26, 2004 Posted July 26, 2004 Turn off opt 7 in sect 381 If you still having problems let me know and I can do a upload/download for you to check your programming... Later Paul There are no stupid questions, but there are a LOT of inquisitive idiots.
