arfur mo Posted June 11, 2010 Posted June 11, 2010 cable, switch or fuse - will only be one of those three but the system may be on "engineer reset" have you always been able to reset the system before? imo unlikely engineer reset due to model of panel and age so you won't need the engneers or master code, it was designed as 'bells only' panel i.e. not for remote monitoring. i never used many but i don't remember it supporting engineer reset if you have motion detectors and the Red LEDs used to come on as you move (some installers disconnected them), are they still coming on? if not indicates likely you have blown the 1amp 20mm glass fuse in the main panel, replacement sourced easily from Maplin's. this is an old panel and if not been serviced for a while, i'd recommend to fit a new 12v 3amp battery, again sourced from Maplins or i think cheaper from TLC electrical wholesalers. Arfur If you think education is difficult, try being stupid!!!!
Guest Oxo Posted June 11, 2010 Posted June 11, 2010 Arf if i`m correct its the same thru the lower series of these panels. So opt 21 0=any code 1 = Master Code 2 = Anti Code 3 Engineer Code Arf if i`m correct its the same thru the lower series of these panels. So opt 21 0=any code 1 = Master Code 2 = Anti Code 3 Engineer Code
IAS Posted June 11, 2010 Posted June 11, 2010 . i never used many but i don't remember it supporting engineer reset I wouldnt have bothered posting about it if it didnt ............ i'd recommend to fit a new 12v 3amp battery, again sourced from Maplins or i think cheaper from TLC electrical wholesalers. Arfur get it from Maplins - then it`s easier to take it back there the next day to get one that fits* * yuasa 2.1A will do it.
james.wilson Posted June 11, 2010 Posted June 11, 2010 i think the bwf might be changing something to sir securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
IAS Posted June 11, 2010 Posted June 11, 2010 i think the bwf might be changing something to sir Nah dont burst my bubble LOL. not at all, credit where it`s due ........... same with Arfur and the "fast mon." Probably only 5 real engineers on the site ATM.
FASTCAR Posted June 12, 2010 Posted June 12, 2010 The 360 and the 370 were completely different panels. Are you sure you are resetting it properly?. You could link out the bell tamper at the panel , if it clears then the fault is at your repair or the bell box.
scousekevin Posted June 12, 2010 Author Posted June 12, 2010 Hi Guys Thnks very much for all of your help/suggestions, I found a none contacting wire in the cable jointing block I had used for the repair. Simple, though Oh so frustrating. Again Thanks a LOT Kevin
MrHappy Posted June 12, 2010 Posted June 12, 2010 Kev can you break something else ? We only had 20 odd posts of argument of this matter...... Mr Veritas God
