What Equipment Do You Use On Domestic Systems?
What Equipment do you use on Domestic Systems?
31 members have voted
  1. 1. Main Control Panel
    • Castle Euro Mini
      3
    • Castle Euro Meridian
      1
    • Texecom Veritas
      1
    • Texecom Excel
      3
    • Texecom Premier
      4
    • Honeywell Galaxy 2
      2
    • Honeywell Galaxy Dimension
      0
    • Scantronic 9651
      3
    • Scantronic 9751
      0
    • Scantronic Ion 16 / 40
      0
    • Risco Eurosec CP8L / CPX
      1
    • Risco 480 / 490
      1
    • Menvier M550 / 600
      0
    • Honeywell Optima / Accenta
      1
    • MDT
      0
    • Other
      0
  2. 2. Detector
    • Honeywell IS215
      3
    • Honeywell Activ8
      2
    • Bosch Blueline
      2
    • Optex RX series
      0
    • Risco iWise
      2
    • Texecom Medusa
      0
    • Texecom Prestige
      6
    • Scantronic Xcel
      1
    • Pyronix Colt / Magnum
      1
    • Pyronix KX Series
      2
    • ESP Quest
      0
    • Guardall
      1
We use a few,
Wired small no comms = 480 (Only done about 4 this year thank god)
Hybrid with or without comms = CPX with G-Tag Keypad or 595
Mid-large wired 99% with dualcom = Prem 48 and up
One large Hybrid 70 zones = PROSYS (Yuk)
Detection = Texecom prestige for G2
Bells only small = 9651 or risco wireless
Bells only large or anything with coms = Galay 2/44 or G3/48 - 96
Detectors we only use Guardall DT15+ for everything apart from the wire free stuff that comes with the risco stuff.
of late i only use the one panel G595 for wired, updates, wired/radio hybrid systems.
Wisdom and more recently imo the excellent Agility for totally radio systems.
as my business unintentionally gravitates more towards CCTv and Telecoms, Structured cabling (LAN), Access control all with with better mark up, and far less hassles, i've decided it's easier on spares and more cost effective to stock a reduce range of models for panel/keypads. This way radio detectors fit across al three pnaels.
Arfur
Arfur
We have one on he bench, must admit 'excellent' didn't come to mind.
Small domestic M550, 9651 G2-20 ( also wireless), Visonic.
Larger M750 M2000
Commercial M series panel dependant on number of zones. G3 144/520/Dimension.
Was using Crow pir now Honeywell.
persevere is all i can say,
software is very different from the 'g' series panels, but not so different to the Wisdom/ProSys, very versatile kit imo. really like you can give detection voice tags as with the Wisdom
main trick to remember/get used to is to press the 'star' key to wake up rkp before you enter code, a bit usual and i found habit means you enter the code and get a 'reject.code'.
i used the GSM module on the last one, warehouse storage where there is no land line - just spot on.
Arfur
