Adi Posted July 3, 2010 Posted July 3, 2010 I connected me lappy to the above, used 192.168.0.1 to connect but wont have it, is there a way to find its address or should i say what's the easiest way to find it. There are 2 b band lines in this building so i suppose it wouldnt be that bad to look at at network info on each of the computers, would this be the normal way?? This router is connected to atleast one or two rack mount switches some of it ppoe (or whatever it is, if i had a longer patch lead i would have tried connecting into the switch but i would of thought direct to the router should work. chaps I really can't be ar**** with it anymore.
Cubit Posted July 3, 2010 Posted July 3, 2010 I connected me lappy to the above, used 192.168.0.1 to connect but wont have it, is there a way to find its address or should i say what's the easiest way to find it. There are 2 b band lines in this building so i suppose it wouldnt be that bad to look at at network info on each of the computers, would this be the normal way?? This router is connected to atleast one or two rack mount switches some of it ppoe (or whatever it is, if i had a longer patch lead i would have tried connecting into the switch but i would of thought direct to the router should work. chaps cmd line ipconfig that will give you the pc ip address and should also give you the gateway. Normally, that would be the ip address you need to get into the router.
Adi Posted July 4, 2010 Author Posted July 4, 2010 i plugged my lappy into the router and tried that, thought it would show us the info i needed, it didnt. So i should do that on one of their computers? I really can't be ar**** with it anymore.
Cubit Posted July 4, 2010 Posted July 4, 2010 i plugged my lappy into the router and tried that, thought it would show us the info i needed, it didnt. So i should do that on one of their computers? That would/should do it. Did you try ipconfig /renew ?
james.wilson Posted July 4, 2010 Posted July 4, 2010 You may find that the dhcp server has been stopped, so there will be nothing giving out address's. Some people setup networks without dhcp and stataically assign everything. If so as you have noted run ipconfig on a connected machine and it should give the relevant info. You will then need to use a spare address (can loosly check its spare by using ping) and get your laptop on the network that way. Then you can access the pages as needed. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
jb-eye Posted July 4, 2010 Posted July 4, 2010 You may find that the dhcp server has been stopped, so there will be nothing giving out address's. Some people setup networks without dhcp and stataically assign everything. If so as you have noted run ipconfig on a connected machine and it should give the relevant info. You will then need to use a spare address (can loosly check its spare by using ping) and get your laptop on the network that way. Then you can access the pages as needed. Me! Customers!
Adi Posted July 4, 2010 Author Posted July 4, 2010 That would/should do it. Did you try ipconfig /renew ? I thought it should have. No i didnt. You may find that the dhcp server has been stopped, so there will be nothing giving out address's. Some people setup networks without dhcp and stataically assign everything. If so as you have noted run ipconfig on a connected machine and it should give the relevant info. You will then need to use a spare address (can loosly check its spare by using ping) and get your laptop on the network that way. Then you can access the pages as needed. I see, i'll have a go tomorrow. I really can't be ar**** with it anymore.
arfur mo Posted July 4, 2010 Posted July 4, 2010 I thought it should have. No i didnt. I see, i'll have a go tomorrow. router could also have mac addresses filtered to allow only 'accepted' machines to use the internet, seen this done to stop WiFi pirates instead of using WEP Arfur If you think education is difficult, try being stupid!!!!
james.wilson Posted July 4, 2010 Posted July 4, 2010 mac filtering is very low sec, normally used as part of a solution not a solution on its own. ive only seen this implemented on wifi links though, is it wifi, sorry if it is i missed that lol securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
arfur mo Posted July 4, 2010 Posted July 4, 2010 mac filtering is very low sec, normally used as part of a solution not a solution on its own. ive only seen this implemented on wifi links though, is it wifi, sorry if it is i missed that lol don't shoot the messenger Arfur If you think education is difficult, try being stupid!!!!
