Dedicated Micro Dvr + Ptz Compatibility
I have a customer who has purchased a second hand DM DVR and an unbranded PTZ.
We have having problems getting the DVR to control.
If correct I seem to recall that a BBV interface( or somthing like this) is required.
Can anyone confirm OR should the DVR just control PTZ just like with a normal DVR..
There is no problem with protocol and both are set to Pelco D 2400 baud.
Many thx
Chris
Not trying to teach you to suck eggs I hope, but is Polaruty of twisted pair right, and the address right ?
Some budget domes= Cop ones anyway wont accept programming pre-sets under No 16 with DM Sprites for some reason
Edit. Come to think of it, I'm not sure that DM units support Pelco D.
Just checked a site that I cover and Pelco D doesn't show up in the list of protocols. (DS2)
Pelco P or Pelco Coax only.
Pete Bennett
Northern CCTV Services
T: 0845 838 7383
E: info@northern-cctv.co.uk
www.northern-cctv.co.uk
The one i just checked was running
Software Version: 04.5 (062) M2IP - 03.1 (09.2)
Which should be the latest version, loads of protocols on there but not Pelco D sadly.
Pete Bennett
T: 0845 838 7383
Easy way is to use a BBV in-coax RX100 Dome Interface Receiver
Compatible with the following:
360 Vision, Borsatec (BT2790FF), Chugai (SMD-0811, SMD-12, SMD-12ii, SMD20), Dennard (20XX), Diamond Smartscan, Dynacolor (7720), Forward Vision (MIC1300), Kalatel Cyberdome (Jan 2002 or later firmware),
Merit Lilin (PIH-717X/7000/7600/7625PF/7625DWPF) Mark Mercer (D250MPT), Panasonic (WV-CSR400/600/650), Panasonic (WV-CS850/860/960), Pelco Spectra & Esprit (Pelco P Protocol), Philips/Bosch, Samsung (SCC-641), Sanyo (VCC-9200P), Sensormatic Speed Dome (RS422 Only), Sony (EVI-D31/1000), Star (MD-800/1200s/1200h/2000), Ultrak KD6, VCL-TP, Vicon Surveyor, Videcon Dome, Videcon Camera (VCP451), Vista Power Dome.
Please contact Building Block Video for further information if your dome does not appear in this list.
Never had a problem yet.
James, Got the info connecting through netvu observer and then into config.
Seems an RX100 could be the way to go.
Pete.
Pete Bennett
T: 0845 838 7383
