cashel electrics Posted July 8, 2010 Posted July 8, 2010 If I have one prox tag and two keypads can I part set the system at night from the upstairs RKP and full set at other times by using the same Prox tag with the downstairs RKP? The panel being used is a Scantronic 9751. Sorry for the silly question but i don't have much experience with scanny panels. Many thanks www.cashel-electrics.co.uk
hpotter Posted July 8, 2010 Posted July 8, 2010 If I have one prox tag and two keypads can I part set the system at night from the upstairs RKP and full set at other times by using the same Prox tag with the downstairs RKP? The panel being used is a Scantronic 9751. Sorry for the silly question but i don't have much experience with scanny panels. Many thanks Yes, but.. present tag press B (night - Bedtime stiing), or tag A (or tick) for All on.. (but was I assume you wanted to just use tag, which case no, though could add RFX then use telecommand?)
