Duress On Gardtec 816
perkinogg
managed to put a duress code in my 816 panel when setting my alarm what is it is it the same as the 872 panel eg code is 4546 duress is 5546 is this the same on the gartec 816 because it does not tell you in the book thanks mark
I'm not familiar with those panels so i can't answer your question ...... but duress was really only used on systems with Police response and that facility is no longer allowed on new systems by ACPO (Association of Chief Police Officers) rules, so we don't programme a duress code now.
yes you add 1 to the first digit, often triggered in error by the way tags "auto" number themselves if you have the engineer code you can disable it under the panic menu.
