scratchhead Posted July 13, 2010 Posted July 13, 2010 Hello there, I have a BT Versatillity system that is not releasing line one after a call has finished. Anybody got any idea's about how to fix it? scratchhead
Guest Oxo Posted July 13, 2010 Posted July 13, 2010 On analogue lines? Checked the programming. If not Sounds like the module. In the control unit. Is there two fitted? Try a swap. Believe you can hot swap them
