One Panel To Rule Them All
r24977
use it to label quite a lot of bits eg spurs if side by side etc.
dont use to label cables anymore too much pita. use resistor colour code grommets these days.
True never label cables as such.
Used to a numeric sticker you can get from wholesalers. Similar to your grommets but more like a hand held printer label.
I so hate people that write on the outer insulation, how freakin hard is it to read when its busy in there!
Numbers are best and I tend to use the zoning with it also.
So cable 1 = zone 1 or 1001 ect.
Cable labels
tried them too, but ended up prefering these.
dont need to squint to see cable number (unless colour blind which case wrong job).
cable 2013 red,black,brn, orange. they got the digits on too.
post-17665-061319700 1289928057_thumb.jp
(cable 024 as above :'( )
Rofl, you`ll make sure next time to take a better photo!
As I said James, markers are *****. Some numbers to imitate zones ot a small card with an index ( My perfered method). Takes a few mins on overall install, but saves eons when chasing cables about.
A small cost for a time saving method.
Use them anywhere Fire , CCTV need I go on.
The ones I posted and use wrap around themselves and stick. Not had one fall off yet.
yep, as with the grommets, dont slip off & come in different girths too.
(dont be smutty)
