Cooper Menvier 9651
madern
You mention contacts, yet only front door being done? if just the one door this might help.
post-17665-091932900 1280053961_thumb.jp
thanks for drawing,what is junction in panel,ie pir and front door contact,is it a straight forward conection between the pir and door contact all the best.ern
sorry yellow crayon broken, might be bit clearer.
the junction is to wire the tamper ccts in series, and yes just twist the two green wires together in panel & put in terminal block.
