Eurosec Alarm
Guest EAD
Hi there, just recently moved into a rental property with a Eurosec alarm fitted. Panel shows 'Enter Code Check'
Landlord wasnt sure of code so is this something that needs the installer to sort or could I get any alarm people to deal with :unsure:
Yes, installer or other eng needed unless its still on its default of 5678.
The landlord should pay any costs involved in issuing a new code.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
What area are you in Ead_* ?
obviously not in richl's
If it was advertised as having an alarm then yes but be sure to check 1st.
Thanks for the quick replies ;)
Landlord hasnt sorted it though I havent pushed for it to be either.
Can I test it if default code works somehow :unsure:
I have no idea of zoned areas either.
Ohhh btw im in Northern Ireland but guess that isnt richls area :lol:
You're right its not!
Try 5678 once, if there's no acceptance tone then its not that and you need to either get a eng out to issue a new code or trace the old occupier to see if they know it.
