SUBS Posted August 21, 2010 Posted August 21, 2010 One thing to look out for is. Is there any pressure on the strike plate, cos if there is it wont release, try it with the door open. Apply light pressure against the plate and you'll see what I mean. 75% of the time this is the problem in my experience, adams rite strikes are pretty reliable. I know the strike you mean, looks similar, but with a large ish brass screw at one end, annd swapping the pins changes it from fail open to fail locked ?
SUBS Posted August 21, 2010 Posted August 21, 2010 Apparently it's not the model in the photo. Agreed, very odd for two strikes to both fail with same fault. Sounds like it might be a Trimec one then ? Same applies, I'd try norbains website for a instruction manual.
Guest Oxo Posted August 21, 2010 Posted August 21, 2010 Deffo a Trimec you have mixed up the pins which as mentioned facilitate fail open/fail safe. As before pull apart the other one and remake both the same. Both locks not locking would indicate a failing PSU, or both???relays going on keypad?. They both on same supply? Also is there a varistor fitted? This diagram should be of help.
Bibbage Posted August 21, 2010 Author Posted August 21, 2010 Deffo a Trimec you have mixed up the pins which as mentioned facilitate fail open/fail safe. As before pull apart the other one and remake both the same. Both locks not locking would indicate a failing PSU, or both???relays going on keypad?. They both on same supply? Also is there a varistor fitted? This diagram should be of help. Thanks for that spot on, I got it right and as someone else has already said there is pressure on it when the door is closed, so pressure has got to taken off before it will open. Great thanks
arfur mo Posted August 21, 2010 Posted August 21, 2010 I would also clean out the oil and use graphit powder or dust will stick causing probs later. Arfur If you think education is difficult, try being stupid!!!!
