Galaxy Max Reader
rossibufc
Need some help here please. Never installed a max reader on a galaxy before and the customer wants one just to go through door. They want 6 fobs to just work on the max reader and another 4 fobs to unset/set alarm at keypad and also to work max reader.
The max reader is only to go through door as there is a menvier zone omit module on the inside of a 24 hour door and max reader on the outside. I assume I need the reader to drive a relay to short the contact on the zone omit module to allow door to open. I also assume I need an egress switch on inside to allow access back outside.
But how do I program this up from keypad. cheers in advance.
Why not dump the Cooper/Menvier omit unit and have the Max run the lot.
That way any usage will be logged as well.
