Cowboy Installer
Specialist
seen loads on plug tops, mainly due to sub not getting spurr in time but insisting on working system, document and advise.
Only advice I gave him was get a new system, he's had the old system 11 years.
This is fairly typical around here. If they are really good they use mini trunking
Classy & with a bit of thought it would have been so easy to do it right.
Sorry guy's not going to be any pic's of this 1, went to see the owner this morning & found he's had someone in to do it.
Nice of him to let you know!, prob gonna be to the same standard as it was before then eh cost wise :whistle:
Probably not even that good, the original kit was good quality it was just the installer let it down. This 1 is of the unmarked white bellbox brigade & at the price he charged I doubt anything else was quality either. :realmad:
like i said before, dodge the **** customers, not worth the time of day. I would bet money on the national telling him it should be put right, but he wanted a cheaper option.
Otherwise he would have just changed to another approved company and got it all sorted and kept it monitored.
Not a Monitored system, just 2 external sounders fitted apparently taken off monitoring a few years ago, National were servicing as is up until a short while ago.
...and prob documented on eng's reports.
Service reports just showed readings taken on system at time of service, call out log on each sheet I saw just said that the system had been checked but no fault found. :hmm:
What readings were taken?
Would they have been enough to trace a fault?
