Visonis Power Max Wireless
skaterboy
I have installed this panel in my house and it works fine apart from when it is in alarm and i silence the panel the external bell continues for about 30 secs then stops.Anybody any ideas?
Ditto the above, check signal strength.
In diagnostics menu.
I have also noticed a slight delay on these but not to that extent.
How often does it go into alarm?
signal strength is very good,I only discovered this with testing system so it is not in alarm for long.Also found it takes longer to silence depending which zone I activate eg zone 2 silences after about 2-3 sec but zone 3 takes 10-15 sec
