mecheng Posted October 14, 2010 Posted October 14, 2010 Ok.. In the past I fitted alarms, but gave it up for a number of reasons(!) so I know my way around systems quite well, but I'm stumped...so I thought I'd sneak in here!! my panel has decided that the code has changed from 1234 to 2341 (obviously not the real numbers!!!). Now no-one has been near it to reprogramme, I've powered it down completely (mains and batt) to reset to no avail, next stop clearing NVM and reprogramming, but just can't understand why - any suggestions? Thanks Si. Edit for Speeling!
Guest Oxo Posted October 14, 2010 Posted October 14, 2010 How did you find the lost code? That is a lot of sequences to go through!!!!
mecheng Posted October 14, 2010 Author Posted October 14, 2010 How did you find the lost code? That is a lot of sequences to go through!!!! Chance!! putting the code in twice turned it off, so by elimination...
mecheng Posted October 14, 2010 Author Posted October 14, 2010 yes and ??? ...but no its not that simple having reset it, gone into programming made etc etc its definately changed the order (I spec, programme install all sorts of control systems so I usually know when I'm making an 0ss of myself) but before I faff around clearing the NVM and reprogramming, I'm trying to work out whther I'm just wasting my time and I should change it...
Guest Oxo Posted October 14, 2010 Posted October 14, 2010 So what was lost and discovered, the end user or the engineer code?
hpotter Posted October 14, 2010 Posted October 14, 2010 I assume your old code began with 8 & you accidently pressed prog before your code....
mecheng Posted October 14, 2010 Author Posted October 14, 2010 'hpotter' - I did think about that as being plausible, but with no 8 in the number and no admission of guilt from other fingers had discounted it - will have to go home with the thumbscrews to find out for sure! Thanks ! (maybe I can still use it as the excuse I need to put a better panel in though!)
hpotter Posted October 14, 2010 Posted October 14, 2010 well as you know the code accident or not, simple to change back. (if not can do from eng code) might be worth keeping master code to yourself and setting up 2nd user code for rest of family, cos iirc 2nd user cant change codes?
