british gas dac contols
ackers
help i have an engineer currently onsite to fit an external bell on a british gas alarm ,the contol panel is a dsc any help would save me money!!!!!!!!!!!
Trade Intruder Member
What do you need to know?
And are you in the trade?
18593[/snapback]
Yes we are in the trade,basically i have an engineer on site in Cornwall installing an external sounder (british gas never fitted one).
So i we need the sas connections at the control panel end.From what the engineer tells me its a DSC contol panel with only numbers on the PCB .
Thanks
Sounder Negative to AUX - on the DSC
Hold off positive to Bell + on the DSC
Bell Trigger to Bell - on the DSC
Strobe Trigger to PSM1 on the DSC
TF to Earth on the DSC
Tamper to Zone(spare)
You may need to alter the programming too!
18599[/snapback]
DO YOU HAVE A MANUAL THANKS
I do,
but the manual wont help you, unless you know the British Gas engineer codes in the area you are working, otherwise you will need to default the panel completely.
As I don't know you, and am not sure if you are in the trade or not then i won't pass on a manual.
If you are in the trade email or pm your details, so that i can verify who you are and I will then help you further.
Colin.
You wiil need a 1k res across Bell + & bell trig - in the sounder as well ;)
