eagertolearn Posted October 14, 2010 Posted October 14, 2010 Hi Going to connect an Informa Speech dialer to my Scantronic 9651 panel we work 5 minutes from home so its just a little extra security. It can only be connected as (Bells only ) and in the manual I've got these connections Comtrol Panel Informa Bell B- ------------IP1 IP2 IP3 SET ---------------INH and in the Panel I've got OP1 OP2 OP3 TR + - spkr Manual says connect on bells only to bell output in this case that would be OP1 were is the 2nd core of the dialer connected to ??????? or does it not matter. Thanks for any advise LG
arfur mo Posted October 14, 2010 Posted October 14, 2010 depends, I don't know this dial unit, but most have several inputs. You can use one for your alarm and say another for a bilge pump,so just an optional trigger used as you see fit Arfur If you think education is difficult, try being stupid!!!!
james.wilson Posted October 14, 2010 Posted October 14, 2010 It will have a set of 12v connections too. The bell output can then as you note connect straight to input 1 securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
eagertolearn Posted October 14, 2010 Author Posted October 14, 2010 depends, I don't know this dial unit, but most have several inputs. You can use one for your alarm and say another for a bilge pump,so just an optional trigger used as you see fit Arfur So If I just connect to the bell output power suply that all......... the second cable core is'nt used LG
Guest Oxo Posted October 14, 2010 Posted October 14, 2010 Nope but if your on a boat i`d insulate it.
arfur mo Posted October 14, 2010 Posted October 14, 2010 So If I just connect to the bell output power suply that all......... the second cable core is'nt used LG think we perhaps need to clarify for the eagertollearn a bit more of the basics before total confussion sets in . 'bell' is an old term that still survives, dates back to 1st alarm systems when we actually used bells. today we use sirens. the 'bell' output is not the same as the 'bell' supply. in the control panel there are marked terminals best to refer to your engineer manual for clarification, for simplicity and so you better understand, the dialler needs 12 volts to power it (taken from the 'bell' or auxillary supply in the panel) or nothing is going to works. if you then simply connected a link from the negative (-) power in terminal, then touched it onto an iput, that input will then operate and dial out. so if you connect the the 'bell' output to your selected input, hook in the telephone line and wallah! (some bloke in an annoying Idian call centere gets a call lol!). good luck with it, as they can be frustrating (the diller that is ; ). Arfur If you think education is difficult, try being stupid!!!!
hpotter Posted October 15, 2010 Posted October 15, 2010 dont mess with the bell output etc, too much poss agg, totally unnecessary, and far easier & more pro way of doing it. Use the molex plug that comes with the panel. wire the yellow & orange wires directly to trigger inputs on dialler (for pa & intruder). Panel is pre programmed so no need to change anything (except poss the trigger polarity if dialler not -ve & dont use informer so not 100%, but surprised if dont). also will need 12v to power informer, would prefer off aux 12v.
