Adi Posted October 18, 2010 Posted October 18, 2010 them ip boxes are an eyesore. There's someone round here doing it, bullet cam screwed to the lid of a 100mm x 100mm ip box It doesn't matter if the cam is fixed to the ip box or mounted next to it, it looks bob. I'm not a fan of the large ip boxes with flexi conduit going to a dome or bodied cam but that depends what building its attached to. On an industrial building it doesnt look to bad I really can't be ar**** with it anymore.
james.wilson Posted October 18, 2010 Posted October 18, 2010 i dont think that it looks so bad, and you do need to join the cables somewhere. Some of them typpes do have a wall mount bracket that allows joints etc. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
arfur mo Posted October 18, 2010 Posted October 18, 2010 them ip boxes are an eyesore. There's someone round here doing it, bullet cam screwed to the lid of a 100mm x 100mm ip box It doesn't matter if the cam is fixed to the ip box or mounted next to it, it looks bob. I'm not a fan of the large ip boxes with flexi conduit going to a dome or bodied cam but that depends what building its attached to. On an industrial building it doesnt look to bad going to depend on circumstances, i don't think i'd fit any by the front door for instance lol!, can often hide the box away from view, just undere the eaves, around the corner etc, you get about a meter of lead on the cameras i buy, and you can get much longer. suppose its the service engineer deep in me , ease of replacement/testing imho is always to the fore in my works. i think about for when its out of warrenty. if cable is drilled direct, concealed into the render, or the plaster inside, then terminated inside in a j/b elsewhere and decorated, its likely a job on the decor to replace it. Arfur. If you think education is difficult, try being stupid!!!!
7777777 Posted October 19, 2010 Author Posted October 19, 2010 thanks for the replies,, i checked with the shop the cable did not come apart ,, so had to drill 25mm hole with seems a bit silly and harder work really,,, drilling was no probs as im a plumber,, just looked an hard way to do it
arfur mo Posted October 19, 2010 Posted October 19, 2010 Were you installing closed piipe tv'? Well done, thanks for replying back Arfur If you think education is difficult, try being stupid!!!!
jb-eye Posted October 19, 2010 Posted October 19, 2010 them ip boxes are an eyesore. There's someone round here doing it, bullet cam screwed to the lid of a 100mm x 100mm ip box It doesn't matter if the cam is fixed to the ip box or mounted next to it, it looks bob. I'm not a fan of the large ip boxes with flexi conduit going to a dome or bodied cam but that depends what building its attached to. On an industrial building it doesnt look to bad I install the 4x4 on every camera. Even above the false ceiling with the camersis fixed to the box through the tile and cables going back entry to. Personally i think its a lot more proffessional than the rats nest i see in most dome camera enclosures or the loose wiring above the ceilings worse is the stupid method of entry into the cameras Mine are mostly 20mm MBB via a PG reducer which incidently is how the things were designed to be installed. Customers!
Adi Posted October 19, 2010 Posted October 19, 2010 Have i read that right, You fix plaggy box under ceiling tile, then fix cam to the lid? I really can't be ar**** with it anymore.
Rulland Posted October 19, 2010 Posted October 19, 2010 Have i read that right, You fix plaggy box under ceiling tile, then fix cam to the lid? I read it as cam is fixed through tile to plaggy box-ie box gives cam support from above and cables in box/void nice n neat.
Adi Posted October 19, 2010 Posted October 19, 2010 If thats the case, thats fair enough, nothing wrong with an ip box thats not seen. My earlier posts were on about the local cowboys and indian fitting bullet cams to 4" ip boxs mounted outside at about 2.5 metres. I really can't be ar**** with it anymore.
Guest Oxo Posted October 19, 2010 Posted October 19, 2010 I hate seeing cams mounted on IP boxes. You get a lot of space inside the slightly bigger domes and all plugs can hide in the back. Or you make room behind the dome, its not difficult.
