THE VIKING Posted November 5, 2010 Author Posted November 5, 2010 I have wired the pir detector with 6 core and have not used any EOL resistor and all of the tamper circuits are in series and terminated in the panels tamper terminals
Guest Oxo Posted November 5, 2010 Posted November 5, 2010 Ahhh, a man who understands series and parallel.
Rulland Posted November 5, 2010 Posted November 5, 2010 Unlike 99% of sparks who wire tamper in parallel......
MrHappy Posted November 5, 2010 Posted November 5, 2010 I have wired the pir detector with 6 core and have not used any EOL resistor and all of the tamper circuits are in series and terminated in the panels tamper terminals you will then need to program each zone wired this way as doubled poled, Mr Veritas God
Guest Oxo Posted November 5, 2010 Posted November 5, 2010 Unlike 99% of sparks who wire tamper in parallel...... Their error.........
THE VIKING Posted November 5, 2010 Author Posted November 5, 2010 you will then need to program each zone wired this way as doubled poled, So what part of the menu is this in then ? I I have also just looked through the manual I have and still cant find the factory defaults anyone know what page they are on ? Thanks Mark
reidy Posted November 5, 2010 Posted November 5, 2010 Ok then, when you power up the system it will go into alarm and you will need to silence it using the user code. This is because as default these panels come programmed for EOL circuits Once you have silenced it, enter the default engineer code and the keypad will say "confirm devices" press "yes" twice to confirm the devices connected to your network bus. Press menu "twice" to return to the main option menu's Things you will need to program for a typical bells only setup: Program your zones according through the Zone Setup menu and you need to change the zone wiring to "Normally Closed" Change the arming mode to Timed Exit via the Arming Options menu, you change the Entry/Exit time in this menu as well You need to disable Anti Code Reset and Confirmed Reset, this is done in the Arming Options menu Program your user codes in the "Setup Users" menu Program your engineer code, set the date/time, walk test the system and test the bell via the "Engineer Utils" menu Choose which zones are on during a part set through "Alter Part Arms" (anything ive missed guys?) If you've got the PDF version of the manual, take a laptop Hey Ho, Lets Go
Rulland Posted November 5, 2010 Posted November 5, 2010 Mark, The premier is a very versatile and pro bit of kit, usually installed by intruder engineers who do what they do best!. Don't get me wrong-we have seen diy installers do it-but it's few and far between. The prem stuff IMHO is very user/engineer friendly-though quite in-depth for your normal diy/electrician type person.
THE VIKING Posted November 5, 2010 Author Posted November 5, 2010 Mark, The premier is a very versatile and pro bit of kit, usually installed by intruder engineers who do what they do best!. Don't get me wrong-we have seen diy installers do it-but it's few and far between. The prem stuff IMHO is very user/engineer friendly-though quite in-depth for your normal diy/electrician type person. Hi there Richard I do understand what you are saying but as I allready stated I would normally use a scantronic system that are also aimed at the Pro market and not the DIY sector. As I was about 200 miles from where I nornally work and had this alarm job put on me I had to use a supplier I have never used before who did not have Scantronic Products And was imformed that it would be easy to program so i took his word and bought the kit. But now lets hope you now understand where I am with reguard to getting this thing up and running so that I can first get paid for the kit used and second then charge the customer my labour charge. so what Im realy after is help so that I can achive this . Thanks Mark
THE VIKING Posted November 5, 2010 Author Posted November 5, 2010 Ok then, when you power up the system it will go into alarm and you will need to silence it using the user code. This is because as default these panels come programmed for EOL circuits Once you have silenced it, enter the default engineer code and the keypad will say "confirm devices" press "yes" twice to confirm the devices connected to your network bus. Press menu "twice" to return to the main option menu's Things you will need to program for a typical bells only setup: Program your zones according through the Zone Setup menu and you need to change the zone wiring to "Normally Closed" Change the arming mode to Timed Exit via the Arming Options menu, you change the Entry/Exit time in this menu as well You need to disable Anti Code Reset and Confirmed Reset, this is done in the Arming Options menu Program your user codes in the "Setup Users" menu Program your engineer code, set the date/time, walk test the system and test the bell via the "Engineer Utils" menu Choose which zones are on during a part set through "Alter Part Arms" (anything ive missed guys?) If you've got the PDF version of the manual, take a laptop Thanks for your reply this is the type of help that I need I will not be at this job next week but will be the week after so hopefully by then I will have enough replys to get me on my way with sorting this issue. When you say take a laptop is that for internet access? As I dont own a laptop. And as ihave now had this powered up is it best to power it down and do a reset ? by just repeating the powering up sequence in the manual? Thanks Mark
