Texecom Zone Zttributes
ryan042000
hi there i have a texecom prem24 and i have the id24 expander fitted all detectors work perfect except 1 i have assigned the shock attribute to a viper which is suposed to swith the entry/exit zone to a instant ( guard ) zone for a few seconds however when the detector is activated it causes a full alarm can any one shed some light on why this happens or is the zone programming incorrect
thanx
What do you want this circuit to do mate. Is it to start entry time or be delayed after entry time.
Alter ill change your account to trade only later.
James
why? did i ask you to do that?
i posted part of an engineer manual in error.
Is it possible to view only topics posted by bona fide trades persons?
Could an admin please set me up to view only trade related posts please?
Ronnie
thanx
I think your going to want to use zone type 4 - Guard Access
4 - Guard Access
normally used for detection devices along the entry/exit route.
This zone type will allow the user to walk past the detector
without causing a ‘Fault’ during the exit mode or an Intruder
alarm during the entry mode, however, the zone will cause an
immediate Intruder alarm if activated at any other time. This
zone type will also start the entry mode when the system/area
is part armed and activate any output programmed as ‘Guard
Access Alarm’.
I presume you have used this option
! - Shock
Zones with this attribute will cause any ‘Entry/Exit 1’ zone type
to automatically become a ‘Guard’ zone for 10 seconds.
Zones without this attribute will respond as normal.
If so that is designed to make an entry door circuit become an immediate zone IF the shock sensor on the front door activates before the door opens etc.
I dont think that is what your wanting to achieve
that is exactly what im trying to achieve but the system goes into full alarm evry time the shock sensor activates
