9448 - swapping shock sensor for PIR
Guest Ian
I have a 9448 Alarm system with the Engineer codes and of course my main code,
I would like to swap out a Shock sensor for a PIR. (Changed patio slider for
french windows)
IF I place the system in program mode will it allow me to remove the shock sensor
and replace with PIR?
OR .... will it come up in a 'panic/tamper' alarm?
Any help appreciated before I wake up the neighbours! :D
Regards
Ian
You should be fine in engineering mode so long as you remove the AUX feed to the detectors before you start messing, just so`s you dont blow any fuses.
