Pyronix Deltabell Plus Onto Existing System
grobes
Hi there.
Existing Pyronix system with Belle sounder on front of property, have just upgraded it fitting a deltabell plus box at the rear of the property too.
Cannot figure out exactly why the strobe on the belle wont stop flashing ? Other than that everything is working fine. Disconnected the strobe on the Delta for now (which has temporarily cured the problem on the Belle).
Any thoughts appreciated. Thanks.
Hard negative in the wrong place?
Look at conections again and follow back. your putting a trigger onto the strobe.
Yeah you must have a permanent (-) to the strobe of the belle, or maybe its back feeding somewhere if disconnecting it on the delta has stopped it flashing?? What you done with the 0v and tampers?
