Guest hopo26 Posted July 27, 2004 Posted July 27, 2004 help please have a customer who requires a wire telecommand button and P.A for upstairs, i have installed a karisma plus and have used a 4 channel reciever, and a 3 channel transmitter all ok. I have programmed in the 1st channel on the transmitter as a keyswitch when pressed it sets the alarm but will not turn it off if pressed again what am i doing wrong....
morph Posted July 27, 2004 Posted July 27, 2004 How have you programmed the setting final exit/timed etc?
Guest hopo26 Posted July 28, 2004 Posted July 28, 2004 i have programmed it as timed exit should it be as pts
BUSTER Posted July 28, 2004 Posted July 28, 2004 You need to put a biscuit over the n/c contact of the relevant relay and programme it as keyswitch Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
Guest hopo26 Posted July 28, 2004 Posted July 28, 2004 hi i did that and it sets the system fine but will not unset the system i have to put in the code any ideas or is that the limit of the key switch
morph Posted July 28, 2004 Posted July 28, 2004 try opening the final exit door and then pressing the remote ie start the entry timer then switch it off with the remote.
Guest hopo26 Posted July 28, 2004 Posted July 28, 2004 i will try that and see what happens alarmgard
