mikeald Posted July 27, 2004 Posted July 27, 2004 Hi there, i am in the middle of installing a large galaxy 504 system, 45 + mods. The problem is that line one seems to have a mind of its own, by that i mean that when i introduce new rio's, and keypad onto the system and then exit engineer mode to scan the line for new mods added, it does not come up with them! and it is telling me that i have removed a module or two elsewhere! The cabling is correctly done using belden, is a perfect radial circuit and i have fitted a 680 eol on all lines. Lines 2,3 and 4 are fine it is just line one. I have tried introducing new mods into the system by wiring them right next to the panel and it still will not pick them up! And I have nowhere near exceeded the amount of mods you can have on line 1. It's just the keypadsthat wont come up, all the rios are on now. Any ideas? Any help welcomed mike Intruder & Fire Member
breff Posted July 27, 2004 Posted July 27, 2004 Have u tried swapping lines and seeing if the fault moves with the line? The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
ian.cant Posted July 27, 2004 Posted July 27, 2004 I am pretty sure that happens due to a software problem, seem to recall someone posting about this previously.
ian.cant Posted July 27, 2004 Posted July 27, 2004 This link will take you to the post i was thinking about but it was an RFI problem, not software. Anyway maybe it will help some as there are some good fault finding idea's here. http://www.thesecurityinstaller.co.uk/foru...?showtopic=2355
Nova-Security Posted July 27, 2004 Posted July 27, 2004 Is there a telecom module plugged on to the circuit board via actual plugs on the pcb ? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Posted July 28, 2004 Posted July 28, 2004 are you using line 1 from the main pcb or the smart psu
mikeald Posted July 28, 2004 Author Posted July 28, 2004 fault occurs only on line 1. no telecoms mod installed, and i am using line 1 from the main pcb. any ideas? Intruder & Fire Member
Guest HomeSecurityServicesUK Posted July 29, 2004 Posted July 29, 2004 Have you checked for the ever dreaded earth fault. I know its a new install but it does happen.......
Guest Posted July 29, 2004 Posted July 29, 2004 have you got too many mods on line one?try removing all from line one then add one by one,could be a problem with the line driver not coping with a certain amount of mods
TSS Posted July 29, 2004 Posted July 29, 2004 there are some addresses reserved on line 1, 13 upwards I think, try changing them to lower numbers. Also make sure you aren't fitting too many prox keypads on one line as there are only a few allowed, 0,1,2,3 I think.. my bet is that you've got a short from the screen to a purlin.... has happened before and my meter couldnt see it! Follow the cable run esp thru corrugated sheets.... James TSS Communication is "A question asked, and an Opinion given." I offer mine to help you with yours. Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
