galaxy 504 line 1 has a mind of its own!!!
mikeald
You can only use keypad addresses 0-2,B,D, F on line 1. On lines 2,3 and 4 you use 0-6 and F. Addresses B,D and F are reserved for Ethernet,RS232 and engineer keypad but can be used for keypads if these modules arent fitted.
thankyou all very much for your replies, alarmbloke may have a point about the prox keypads. how many are allowed on line 1? i think i have 4.
cheers
Intruder & Fire Member
I have come acroos this problem on line 1 once. I spent ages install/unistalling mods. In the end I think i defaulted the panel and it saw them ok aftewards. Must have been a blip in the chip when delivered!!
chris
isc systems ltd
Trade Member
Tip, always cold start a galaxy b4 programming as this will get rid of any rubbish that may be on the system, even on a new panel otherwise you may on very rare occasions get PHANTOM faults!! ;p
