Ad Optima Compact G3 Help Needed Please
arrynev
Hi all,
We have an alarm system called AD Optima compact. It was in our house when we moved in.
When I power up it goes off and I cannot stop it whatever I try. I have tried all the usual, resets but get nowhere,
it does not respond to Factory reset or engineers code. I need a way to reset it or clearing the NVM, any help appreciated.
Very simple for an engineer. Be looking at an hour labour (tops) + new battery and any advisories
Classic fault on these panels, and why it should go in the bin soon as IMHO
Taking all prudent electrical safety precautions , if you have to ask about them - stop reading here!
Ensure mains us disconnected.
Open panel,
disconnect old battery
buy new one from maplins etc. Appx <£20
Being careful, power up with battery still disconnected (i just bet someone aske's me why).
enter code to silence (assuming you know this before you start - or return to go).
wait about 5 mins (just trust me;) )
connect new battery + is Red lead - is black lead
close lid
press 'reset'
Should now be ok and showing power light if old battery was duff, please test detection and sirens to be sure, cal in alarm engineer to advise you properly of updates and improvements.
Arfur
Open panel,
close lid
press 'reset'
Arfur
Thanks, but I don't know the code,can I try something else?
No
The battery charging circuit may also be damaged, you need an engineer.
As above No!
if it was easy to over come the code the intruders would be doing it.
Not a given the charging circuit is faulty, but it is not a most robust panel in that respect, so it is best advice to have a call by an engineer.
Post your area see if there is a local engineer who may sttend
Arfur
as above there is a way to wipe it but for security reasons we cant allow it to be discussed on the public side of this board.
Due to other potential damage as noted etc, id suggest you have 2 options.
1. Call a local specialist
2. Replace it.
The G3, was replaced by the Gen4 Optima and can be bought for less than £30
  • 3 months later...
Guest DAVID
we have followed your instructions as below -at least twice .replaced the battery and we still have a "single " beep every 5 minutes .
Your advice please .Is it more than just a replacement battery???
Open panel,
close lid
press 'reset'
Arfur
