jmfoottit Posted November 28, 2010 Posted November 28, 2010 PLease, has anyone managed to connect to Ricochet with pc com (Com1/rs232) connection ..... not USB If so please could you confirm the handshake? thanks
james.wilson Posted November 28, 2010 Posted November 28, 2010 are you trying to connect a richocet receiver straight into the pc? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
jmfoottit Posted November 29, 2010 Author Posted November 29, 2010 yes, just the pc (com1) to the Com1 on the 32xp-w.
MrHappy Posted November 29, 2010 Posted November 29, 2010 I assume the port on expander is for eng rkp ? Mr Veritas God
james.wilson Posted November 29, 2010 Posted November 29, 2010 I don't think you can connect peripherals direct to the pc com. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
jmfoottit Posted November 29, 2010 Author Posted November 29, 2010 ok, so I can use Laptop (com1)> Pc com > Premier 48 (com1) and run ricochet s/w , and it will work? (Assuming the Premier 48 and the 32xp-w are communicating ok)
MrHappy Posted November 29, 2010 Posted November 29, 2010 ok, so I can use Laptop (com1)> Pc com > Premier 48 (com1) and run ricochet s/w , and it will work? (Assuming the Premier 48 and the 32xp-w are communicating ok) if the question is "can I program the radio attributes of an expander connected to the panel using UDL connect to panel" Yes I believe so Mr Veritas God
james.wilson Posted November 29, 2010 Posted November 29, 2010 Yes you can program the unit via the panel. And you can program the panel from wintex securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
jmfoottit Posted November 29, 2010 Author Posted November 29, 2010 so how are you meant to use ricochet?
breff Posted November 29, 2010 Posted November 29, 2010 The Ricochet Expander has a com port connection, you connect your usbcom/pccom to that and run the ricochet software. I've used a usbcom to connect, haven't tried a pccom The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
