Aj600 Panel
Guest Phill
I AM TRYING TO FIND OUT WHAT VOLTAGE SHOULD BE PRESENT AT THE AJ600 PANEL SCB TERMINALS WHEN THEY ARE OPEN CIRCUIT, WITH THE PANEL IN STANDBY MODE.
IS THE BELL BOX BATTERY CHARGED FROM THE SCB TERMINALS?
ALSO WHAT IS THE VOLTAGE OF THE BATTERY FITTED TO THE BELL BOX SUPPLIED WITH THE A1 AJ6OO PANEL KIT?
Most panels wil have about 13.5 volts for aux out put which is common through most of the system and will also be the same for charging your SAB bell battery
www.AllanMoncrieffAlarms.com
MONTY THANKS FOR THE REPLY.
THE PANEL USES A 12V BATTERY. THE PRESENT OUTPUT FROM THE SCB TERMINALS IS 4.5V WITH NO LOAD. I AM TRYING TO FIND OUT IF THIS IS CORRECT AND ALO WHAT BATTERY WAS USED IN THE BELL BOX.
