Guest Oxo Posted December 7, 2010 Posted December 7, 2010 Regardless of silly comments. We can talk you thru the steps needed if you feel able.
Conel Posted December 7, 2010 Author Posted December 7, 2010 Thank you all for your support Haha, sticking them is definitely an option. As is the cage ) I do think I am able, can be quite technically minded but I couldn't make heads or tails of the programming/installation manual. Is excluding a zone and setting up a new set (say C) quite simple if I have the engineer code? Thanks
arfur mo Posted December 7, 2010 Posted December 7, 2010 Like anything, it is if you know how, tbh I'd be cautious talking you through it as you admit the manual is difficult to make sense of, just prudence about repercussions which could be expensive if you do mess up, and say delete a zone permanenty The manual is wrote for the more experienced, the termanology can be confussing fir those not used to alarms. Really recommend the cage, hunt round the family see who has or knows of has one, but I also do a nice line in hot melt glue if your not lucky . Arfur //and yes I use these gags when selling systems// If you think education is difficult, try being stupid!!!!
hpotter Posted December 7, 2010 Posted December 7, 2010 Is excluding a zone and setting up a new set (say C) quite simple if I have the engineer code? personally i'd recommend getting an engineer in, but no, its not that complicated. it is however easy to slip up. setting up the zones for a C setting is straight forward you just need to go to each zone individually and add a C (eg assuming zone 1 = front door: 01 tick (says zone 1 or front door) press tick again and display will show something like : FE O A B. press C and display will show FE O A B C. now press tick to confirm. problems you will have are, setting the timers & entry method, telling system to give a full alarm if activated. If you see an O in the line mentioned above on the lounge detector zone, you will be able to omit it via the user guide, if not press x4 tick so display shows O.
magpye Posted December 7, 2010 Posted December 7, 2010 I've had a thought, why don't we just post the Install Manual? Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
hpotter Posted December 7, 2010 Posted December 7, 2010 if he googles, he'll get one. even alarm firms are putting them on their websites. that said, i didnt put defaulting info here. There is a line I agree, defaulting is it imo, i have pointed out problems but maybe should of reiterated the invalidating of insurance or any installer guarantee if the op goes diy. then again, what installer gives their eng code/or leaves at default.
james.wilson Posted December 7, 2010 Posted December 7, 2010 I'd agree defaulting is the line. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
9651 Posted December 7, 2010 Posted December 7, 2010 Personally i'd swap the PIR for a pet friendly unit (if correctly sited and the cat(s) is pretty small). If not get some detection on the window(s) of the lounge, with a vibration sensor of some kind. Thus if you omit the lounge you are still protected We'd charge £65+vat for a call to a non contract this would include an hrs labour.
arfur mo Posted December 7, 2010 Posted December 7, 2010 I'm designing a new pet device, works with no wiring or programming required. Think if the bub/party game 'sticky wall'. The pet has a jacket made to fit, be it a hampered or an afghan, fit jacket as Orr instructions, sit 'wall' at near ceiling height, throw pet/s at it wallah! And fun before every set, slogan already sorted - "splat - stick - before it gets nicked" off to now apply for dragons den, tomorrow I'll be a miwionair . Arfur If you think education is difficult, try being stupid!!!!
