Guest andykayll Posted July 28, 2004 Posted July 28, 2004 I moved into a house not so long ago. There is a galaxy 8 plus alarm system installed, but i dont have any codes or information on the system, is there any way of crashing the system back to defaults? Any help would be much appreciated. Andy.
morph Posted July 29, 2004 Posted July 29, 2004 Yes there is and if you contact a local alarm company they will be able to do this for alternatively if you post your area on the forum, one of the regular members may be able to assist you. Colin.
Guest willie Posted August 4, 2004 Posted August 4, 2004 I also have just moved into a House with a Galaxy 8 + system, it used to belong to //.National Installer.// but the previous occupier bought the system over I have no pins etc and have tried the usual defaults to get into the system, have also pulled all the power to the system, but the system remembers all setting within the chip. I would be interested if there is another way of accessing this, can someone help? or where can I purchase another chip. Kind regards Willie
Guest dale Posted August 4, 2004 Posted August 4, 2004 You will have to call out a company to take over the system for you, Galaxys are not easy to program, even when you have the system programming manual! Defaulting the system can be done, but again this information is only available to people in the trade so you will be hard pushed to find out how to default the panel. New chips can be purchased, but only from authorised wholesalers and only sold to authorised trade members. So your best bet would be to post your location and we will see if there are any companies in your area we can point you towards. Dale
Guest Posted August 4, 2004 Posted August 4, 2004 or contact //.National Installer.// there will be a local branch to you... >>>>>>>>>>>//.National Installer.//
Guest andykayll Posted August 24, 2004 Posted August 24, 2004 Programming is not an issue really, I work in an electronics laboratory. THe main problem is re setting the system, sadly, //.National Installer.// have made their own chip which i cannot re program using my software at work, but if only i knew how to crash the system.......
Guest Guest Posted August 25, 2004 Posted August 25, 2004 THe main problem is re setting the system, sadly, //.National Installer.// have made their own chip which i cannot re program using my software at work Total Rubbish any good alarm engineer can do this. Contact a local company or post on the forum your location and one of the engineers will be able to help you. P.s most of us have a tried and tested specialist piece of kit to reset them, no software required, although a cup of tea is a advisable. Colin.
norman Posted August 25, 2004 Posted August 25, 2004 although a cup of tea is a advisable. A biscuit also, would be nice Nothing is foolproof to a sufficiently talented fool.
Guest RICHL Posted August 25, 2004 Posted August 25, 2004 True, both are excellent motivational tools.
bellman Posted August 25, 2004 Posted August 25, 2004 although a cup of tea is a advisable. A biscuit also, would be nice 21618[/snapback] Chocky biscuit was that.... Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
