Guest stevevtec Posted July 29, 2004 Share Posted July 29, 2004 Hi All I've used this config many times and I trust it to work, usually!! We have a digi sprite that we've plumbed into an existing system (foot in the door so to speak). On this system is 3 existing PTZ's with baxall receivers (zr3) The sprite has a remote keyboard for the telemetry /joystick control. Problem------------ We are finding the ptzs are drifting to the right or left or up or down(very slowly) after they we stop manual control. We have recalibrated the sprite keyboard and also tried my workshop one and it does the same thing. Any Ideas? Anyone?? Steve Link to comment https://www.thesecurityinstaller.co.uk/community/topic/3038-problems-with-dm-sprite-2a/ Share on other sites More sharing options...
Rich Posted July 29, 2004 Share Posted July 29, 2004 Hi Steve Have you checked all the terminations for all the cameras on the system. Rich Link to comment https://www.thesecurityinstaller.co.uk/community/topic/3038-problems-with-dm-sprite-2a/#findComment-18895 Share on other sites More sharing options...
Guest stevevtec Posted July 29, 2004 Share Posted July 29, 2004 All checked, but thanks for the suggestion Rich Link to comment https://www.thesecurityinstaller.co.uk/community/topic/3038-problems-with-dm-sprite-2a/#findComment-18942 Share on other sites More sharing options...
Rich Posted July 29, 2004 Share Posted July 29, 2004 Hi SteveHave you checked all the terminations for all the cameras on the system. Rich 18895[/snapback] Im presuming its coax telemetry your using, Its been a while since I used one myself, but what you want to look for is a ringing image, ie it always looks a bit blurred. Telemetry down the coax sits in the sync pulse so if there is a camera on the same ground loop that isn't terminated then you end up with extra noise on the sync pulse which can resemble a telemetry signal pulse. I think thats right Link to comment https://www.thesecurityinstaller.co.uk/community/topic/3038-problems-with-dm-sprite-2a/#findComment-18945 Share on other sites More sharing options...
