Texecom Excel + Dialler connectionI want
Guest RankzeroX
Guest RankzeroX
Hi,
I want to connect my Texecom Speech Dialler to my Texecom Veritas Excel Control Panel BUT I don't understand how to do it (except for the Tamp ^_^ ). I'm french and the english manual is not enough explicit, as you can see below :(
Can somebody help me ? :wub:
Friendly, Rank.
if you connect digi outputs 1-3 to dialler inputs 1-3, input 1 Fire, input 2 Personal Attack, input 3 Alarm. 0v and 12v on dialler to 0v and 12v on communicator outputs.
Message 1 is your Fire message, 2 PA and 3 Alarm.
rankzerox,
Comme Breff dit,
Si vous connectez des productions du communicator 1-3 a entrees du dialer 1-3, entree un feu, entree deux sont pris de panique, entree trois intrus, ov et 12v sur dialer a ov et 12v sur productions de communicator.
Message un est votre message du feu, deux sont message de la panique, trois sont message de l'intrus.
Je suis desole j'ai limite francais.
Clive
Guest RankzeroX
Thank you all !
It seems very easy but what's about the trigger inputs programmed for -ve operation and particulary the resistor ???
I only have an alarm (ni fire, no PA) so I must left the digi outputs 1-2, isn't it ?
Friendly, Rank.
ignore the resistors and polarity, it will work out of the box, if you only have intruder just wire 3 to 3
Guest RankzeroX
Ok, I will test that tomorrow, I install my bellbox and I connect the whole!!
thank you still for all those informations.
Friendly, Rank.
Guest RankzeroX
All is OK !!!!
Thanks again ;-)
Friendly, Rank.
