Mutli-Partitioning Vs Multi-Users
Can name worse, but as you have experience with this i`ll bow to your knowledge.
not sure why its not showing the link, trying again:
www.electropoint.hu/uploaded_files_fck/pima832(1).pdf
i get u'll need to copy past the link to the address bar.
thanks
the worlds worst panel, fitted one, still got one in the stores, going on ebay if i get time.
they gave a free panel out, one to each firm. Possibly about 3 year ago.
Im not surprised they left this country as quick as they came in.
meh, i aint really a "pro", i just need for it to go off and it has been working pretty well, obvs i dont know any others panels but this one wasnt that expensive. it's not for a bank use probably, but i hope it will be enough for a single house! just need it to "see" the burglars! and sms/call it to me. obvious cause i work with computers i wanted to go a little further and explore this world you live in. i find it realllly coool, but i'm a little confused with so much information on so little time (NO, NC, polarity, partitions, CMS, PANEL). anyways i'm way better than a few weeks ago, but really needed to see if i was able to resolve the partition isues.
If the installation (cables, sensors, etc.) is OK and the PANEL running, do you think i should worry the panel missconfigs or "fries" (not sure if its an english term!)?
well, many thank again
Fred
NO = Normally open contacts. NC is nornally closed.
Polarity is -ve and +ve correctly positioned.
Partitions is groups of zones made to respond to codes or assigned to a keypad.
Pamelis just that.
CMS is reporting.
Lost me on the last bit, do ypu mean the "smokes"?
eheh
meant "smokes"!
well the other terms i meant to say i know them already and understant them all (well, almost all probably) :) but appreciate the quick explaining words! i even know how to install a sensor with EOL! (NC or NO) thanks to google and this forum.
really hopping someone figures my partition problem part! how is it on other panels? (panel with ON/OFF on the same button, cause if theres a ON and OFF button its quite easy!))
Look at the post called Primo.
Be here all night trying to explain :D
Prima sorry
I odnt think you want to be using partitions. That appears to be for split system use. I assume you have 1 building?
Maybe a plan would help as i dont fully understand what you want to achieve
Thanks to Adi for posting the engineer manual here
http://www.thesecurityinstaller.co.uk/community/files/file/311-pima-hunter-pro-uk-installation-manual/
i think its doable, but maybe not. i'll try to explain better.
i have 5 partitions including about 15 zones. no zone is assign to more than 1 partition.
like Z1, Z2, Z3 -> part 1
Z4,5,6->part 2
Z7,8,9->part3
Z10, 11, 12, 13, 14->part4
Z15 ->part 5
when i arm (with a partitional code) it arms Z1, Z2, Z3, Z4 and keeps Z5 not-armed.
when maid gets and in enter a master code (assign to her and for all partitions) to disarm the system, instead what it does is arm partition 5 (everything getting armed) so she has to enter it again to disarm.
if someone is moving in the partition 5 while she's getting in the system will start the alarm.
what i needed is that the master code could actually have a default for un-arming. so she would get in, enter her code, and disarm all the armed partition instead of arming the only partition that is un-armed.
well, i hope this explains but i think my english is a bit confusing
many thanks
Fred
Prima sorry
cant find that post! i dont mean to trouble you, but appreciate the help!
thanks
PS- myself have to go to sleep!
OP i think oxo is refering to post in the restricted trade area. As a non trade member you wont be able to see it.
But
Partitions are designed for split systems, ie image 4 seperate buildings with a keypad in each.
What you want to do is part set. But this panel doesnt have the number of part sets you need.
If you have a single normal house (ie 1 front door) then you do need part sets then it will work as you want.
Looking at your manual you have a full set and 3 part sets. If this is acceptable for your arming req id suggest a reprogram to part sets instead of partitions.
Even on a very powerful panel partions would work as this panel does and would assume you wanted to arm the unalarmed partition.
