Advantage ZX6 advice please
Guest Slick
Guest Slick
I've bought a repossesed property that has an advantage zx6 control panel, PIR sensors and tamper devices on the windows.
Obviously I don't have the key code (nor does the estate agents who shall remain nameless).
I want an alarm installed in my house as simply, quickly and easily as possible. The current PIRs and tampers are well distributed so I'd be pleased to use these. Failing getting a key code I was going to try and find an Advantage control panel and replace the old one, but I cant find one.
Or can I just buy another control panel and use the existing wires to plug into it ?
cheers,
Slick
  • 4 weeks later...
Guest khoock
Hi
I too have just bought a house with an Advantage ZX6 panel. I have the codes but have no manual so am unable to do more than turn it on and off. I have tried to look for a manual online but have been unsuccessful. Can anybody help?
Thanks
Khoo
Guest kenny james
B) came across one of these last year,had no manual to it managed to reset user code but would like to have a copy of the manual in case i come across it again preferably information regarding changing exit and entry times thanks or any engineer info thanks : k alarms
If anyone wants this manual can you please email me at webmaster@thesecurityinstaller.co.uk and ill get you sorted out, please no msn, yahoo email addresses.
The reason for this is although i can send emails through the forums I cannot attach anything to the messages, and secondly its a pain to have to get your addresses through the Admin Control panel.
Thanks.
Or get the Quick Referance guide Attached below:
Advantage_ZX6_AJ600N_Quick_Reference.pdf
