Interference On Picture? Adpro
connor2425
Hope you can help,
Got a camera that has developed some kind of interferance in the last month.
It is connected to a adpro fasttrace, this is also causing it not to record on the affected camera, another 5 cams have a little interference and again these wont record? anyone had this prob?
The picture is ok but its the usual lines across the screen, I tried a fresh coax but still the same problem, Im trying a new PSU tommorrow.
What ive found is the problem cam is 1 and when i plug camera 9 in the picture gets abit better but the lines are still there, when i take it out the pic is alot worse.
Anyone any ideas?
Thanks
Ive only had a brief look today, im going to investigate more tommorrow. No seems as tho there is just cameras on the adpro.
Any chance of this being a PSU problem?
also they have put a test monitor local to the camera and its fine, but when i throw a cable across the building the same prob occurs
