numpty-newbie Posted December 15, 2010 Posted December 15, 2010 Need a little help please guys - trying to connect a honeywell activ8 PIR to an accenta gen4 system. I broke an exisiting PIR when decorating (bit too close with wallpaper steamer), got an activ8 as a freebie from a mate but it has different contacts. Old PIR black and red to + and - yellow and white to tamper and tamper blue and green to C and NC New PIR still has 2 tamper and + and - so I assume I wire those four wires the same. This new PIR does not have C and NC, it has EOL, EOL, Relay and Relay? Where the chuff to green and blue wires go?? Much appreciated guys, going away over christmas, would like alarm working before we go! Nick.
james.wilson Posted December 15, 2010 Posted December 15, 2010 relay and relay eol id say are spare connections securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Guest Oxo Posted December 15, 2010 Posted December 15, 2010 EOL TAMP TAMP RELAY RELAY EOL As on the board. Tamper to tampers N/NC To relay relay
eddieeves Posted December 24, 2010 Posted December 24, 2010 Standars wiring (if there is standard) Red 12v+ Black 0v- Yellow/Blue Normally Closed Green/White Tamper. You will not need an EOL(end of line) with that panel. Hope that helps Eddie
arfur mo Posted December 24, 2010 Posted December 24, 2010 Tbh there is no standard colour code used, while many companies do gave and stick to their own for their systems. For instance, many use green + and White - 12 volts, so best to stick with colours used in original pir Arfur If you think education is difficult, try being stupid!!!!
