Scantronic 9751
Scantronic9751
Hello,
Got a problem with a Scantronic 9751 single zone fsl which is as follows ;
When an intrusion is detected the alarm and strobe do not trigger.
I can walk test the system and all the detectors are working (used chime attribute)
I can self test the siren and strobe ports manually, no problems.
Would very much appreciate if someone could help
Many thanks in advance
I assume you mean bell and strobe test via test menu, and or applying hard negs, First thing i`d look at is bell delay.
Has it been enabled?
Many thanksfor the reply
Strobe and bell tests via the test menu and by asserting o/p1 and o/p 2 (command 91)
Bell delay = no delay(default)
o/p 1 and o/p/2 Hard negatives
hope that this helps
Hello,
I have just solved the problem.
Reading the notes and setting accordingly as shown at the end of OPTION 41 BELL Delay
which were as follows : commands:161,162,47,63,73 and 77.
It appears that by having the incorrect settings on the abovementioned commands will inhibit the bell and strobe.
Have just reconfigured the system and set it. When triggered, the external bell(siren), strobe and internal speaker produce the desired effects.
Many thanks in advance and hope that this info was useful.
Yeah thanks.
Nice to know I got it on the 1st reply :D
