Guest Oxo Posted December 19, 2010 Posted December 19, 2010 How big ya want it, nice Bosch could double as a wall light
Guest Oxo Posted December 19, 2010 Posted December 19, 2010 Try that http://www.securityw...products_id=618 the other was a joke, they are big sods Just to add, temp fix it and walk test very carefully before you fix it finally I CANNOT STRESS enough WALK TEST before final fixing.
arfur mo Posted December 19, 2010 Posted December 19, 2010 There will be issues covering the ceiling, so no need ti mask off. Wise to use blue tac and test, simply because the lens is designed to look down onto not across the protected area, the pattern may not be better than 2 detectors back to back. Crow used to make 110deg pir, very good but also ugly (as many ceiling detectors are). You have to realise an intruder will not just enter but usually move about having done so, just be sure the more valuable items are covered. Arfur If you think education is difficult, try being stupid!!!!
