Guest james callaghan Posted December 24, 2010 Posted December 24, 2010 Hi, just set up veritas R8 system, when carried out a part set and activated the system, then performed a reset the External Sounder/Bell box still activated and can't turn off. Checked wiring at both sides both ok. Any ideas? Many thanks
PeterJames Posted December 24, 2010 Posted December 24, 2010 Hi, just set up veritas R8 system, when carried out a part set and activated the system, then performed a reset the External Sounder/Bell box still activated and can't turn off. Checked wiring at both sides both ok. Any ideas? Many thanks Its either wired incorrectly or a faulty bell how have you wired it i.e. what terminal bell to what terminal panel? Of course it may be a panel fault is the panel still outputing once you have reset? and lastly make sure the strobe output is not in anyway connected or shorted with the bell trigger
arfur mo Posted December 24, 2010 Posted December 24, 2010 What siren have you used would also help Arfur If you think education is difficult, try being stupid!!!!
9651 Posted December 24, 2010 Posted December 24, 2010 Is the panel in day? Do you have a return tamper voltage from the bell unit. Either the units in tamper, or you have the trigger of the unit wired into the 0v of the bell (done that before!)
james.wilson Posted December 24, 2010 Posted December 24, 2010 as above need to know what sounder you have. Some sounders have a high security trigger mode that might need a pull up resistor in the trigger if enabled. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
FASTCAR Posted December 24, 2010 Posted December 24, 2010 Make sure you havent inverted the bell output by mistake (options 01 , 6 )
