Recessed Internal Sounder For Honeywell Galaxy 48?
7VEN
As above, can anyone reccomend an internal sounder that can be recessed into the ceiling cavity?
Kind regards
just make sure its 16 ohm, or use 2x 8ohm in series
Someone give Jeff a shout I think hes sourced one for this specific.
Jeff,
Thoughts?
I'd have to calculate it. It's impedance we need to worry about here not resistance as such.
As it's a dimension it would run 2 of these in series, but not 1 directly.
I understand your concern, it was a rough suggestion. Unfortunately is not easy to calculate the exact impedance of a circuit without the frequency ranges of the panel.
Manufactures impedance is based by roughly guessing the applications freq. range anyway.
But I was sure that inductors and capacitors differ between resistance and impedance but a resistance effects an AC wave the same as DC. Therefore I would be sure of getting a similar impedance although due to being a divider may roughly 1/2 or 5/8 the volume.
Vo=Vi(R/(R+Z))
This is not recommended for PA or Music applications etc, due to loss in power equals loss of quality/output which is a waste.
Alternatively running it through an audio transformer of correct impedance values.
