Best Way To Protect Double Glazed Doors
looops
Hi all.
Appreciate any advice on how to protect a room with double glazed windows and a pair of double-glazed patio doors. Can't really use PIRs as there's a dog and some very springy cats who roam freely. I reckon I need to protect against glass breakage as well as someone levering the doors open, or booting them till they open.
I'm thinking a glass break detector in tempered glass mode and a shock+magnet sensor on the double doors.
cheers.
Paul.
Wouldn't disagree but if you have shock do you need glassbreak? I'm not a glsssbreak fan.
Would a shock sensor on one windows cover all the others right across? The windows are two panels high x six panels across.
I'm an IT guy, am I right to understand that with the IP Comm module and the Wintex software I can setup and run the system from a laptop?
Yes you can if you have external access to the ip module.
I assumed sliding patio doors. You may need more than 1 vibro
Patio doors are not sliding, both hinged, one locks and the other slams to it.
Right, still don't like glass break. I'd be using multiple vibros. But I haven't seen it so I am assuming certain things.
agreed + contact on opening leaf.
both leafs ?
yup, both as easy once you have gone to the trouble of cabling/fishing etc
