Engineer Code
Gemini
That is Great.
The engineer code does not have to be totally confidential then, within reason. Also, by keeping the default one, you are not reducing security.
That is Great.
lol, wouldn't say that. I would never keep the default code.
I think hpotter said some scanny panels dis-arm with engineer code a while bk.
tis true, on 9651, providing no ee zone activated lol. other 9x5x can change option in programming (guard code option on/off).
to comply customer must be made aware of forcing user code before eng code (user code ****, 3, 3, tick).
  • 2 weeks later...
Hi
I am new to using the galaxy 3 and I have one at a warehouse refurb for a customer.
We have the user codes and we know that the engineer code is set to default value.
However on accessing panel with user code, option 48 is not selectable to input engineer code.
Need to disable system so that a detector can be re-sited due to building layout.
Any help appreciated.
thanks
peter
That's because your User Code is a USER Code, it needs to a MANAGER Code to access '48'
Give that man a bananna.
Cos he`s correct.
