Spacing Control Panels Further From The Wall
james.wilson
Adrian
You mentioned in antoher thread about testing for access with preset tools and that is why rear cable entries are where they are.
Can I ask what if we as installers decide to mount the panel further away from the wall. Id assume this would break that reg as access would be easier?
i`d assume if you battened out the panel and kept it enclosed all around would help, but airflow might be an issue?
Hmmmmmmmmmmm, so 1½ angle (Ali/Mild steel) pop riveted would not pass either.
As drilling out rivet would expose the entries.
Then again how many times you had to have a stand off?
I assume to bridge existing obstruction like pipe work.
nothing wrong with mounting on a block board sheet and cable behind is there?
Arfur
