norman Posted January 8, 2011 Posted January 8, 2011 buy a bigger panel no need then to extend the cables! Nothing is foolproof to a sufficiently talented fool.
arfur mo Posted January 8, 2011 Posted January 8, 2011 buy a bigger panel no need then to extend the cables! You joint behind it? Arfur If you think education is difficult, try being stupid!!!!
breff Posted January 9, 2011 Posted January 9, 2011 So if there are regs for how much space is behind a panel, all the panels I've seen mounted in lofts between 2 bits of timber dont comply???? The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
james.wilson Posted January 9, 2011 Author Posted January 9, 2011 No they don't securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
arfur mo Posted January 9, 2011 Posted January 9, 2011 rarly with a gal as it has that huge opening. but i think it rasies an issue i hadnt thought of before. You say a 'huge' opening, is this because those that use it are very short sighted, or is this Reg to prevent rodents nesting in galaxi panels? . Wonder how msny panels out there i've seen the case stood off on conduit connectors or cable glands? Sometimes the chosen position surface is so ruff or poor you have to fit a board to stop warping the case if nothing else, beer cellars in old boozers come to mind (not old boozers in the cellar before anyone chimes in ). Arfur If you think education is difficult, try being stupid!!!!
arfur mo Posted January 9, 2011 Posted January 9, 2011 No they don't To be clear, regs say batten off is totally banned or has a maximum thickness? You could use 2 bits if scaffold planks side by side, but any gap between then it would not then comply? Do seem a petty rule, what's the harm as long as case is secured properly, screwed through batten into main building structure and tampered to the same? (i.e. not to the batten). Some houses have tiles, no choice but ti drill through to battens to fix EWD's, proper back tamper can get real tricky. Arfur If you think education is difficult, try being stupid!!!!
james.wilson Posted January 9, 2011 Author Posted January 9, 2011 I think caution should be used when not using existing structure ie adding something that could be argued is weaker than the wall. As I said its something I hadn't thought of before, ie spacing, i wouldn't leave the back open. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
arfur mo Posted January 9, 2011 Posted January 9, 2011 Guess most would be the same, panels differ in how much space there is, but what us 'acceptable' to one is different to another engineer. A decent void behind aids wiring ease snd panel neatness, arguments both ways could be had. Arfur If you think education is difficult, try being stupid!!!!
norman Posted January 9, 2011 Posted January 9, 2011 You could drive a bus behind a TS790 Nothing is foolproof to a sufficiently talented fool.
james.wilson Posted January 9, 2011 Author Posted January 9, 2011 i see that as a tsi challange? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
