alterEGO Posted January 11, 2011 Posted January 11, 2011 assume your customers can set/unset from similar beach? (unless you holiday with them ) no, they could, but i wouldn't allow them the opportunity of either.
thealarmingman Posted January 11, 2011 Author Posted January 11, 2011 assume your customers can set/unset from similar beach? (unless you holiday with them ) WOW hornets nest methinks. Mesh sounds good but no outdoor sensors. Visonic Complete/Pro has outdoor sensor, wireless keypad (no wires through stone walls), can partition (new) for gardener to disarm external sensor. Unfortunately, long conversation with Texecom only gives signal advantage but no externals. Had forgotten Risco, but think their keypad also needs to be wired - need to check. Have no real knowledge of Scanny but have a feeling keypad wired. Thanks for the crack. BTW, is there an advantage to being a member?
alterEGO Posted January 11, 2011 Posted January 11, 2011 BTW, is there an advantage to being a member? You get the chance to read my posts. Risco Agility has the only fully wireless engineer access LCD keypad AFAIK We have one on test, but so far we have always been luck (or highly skilled) enough to be able to get a keypad and bell cable installed out of sight.
Cubit Posted January 11, 2011 Posted January 11, 2011 got no axe to grind, nor am i selling I think James is after some commission.
sjsturner Posted January 11, 2011 Posted January 11, 2011 WOW hornets nest methinks. Mesh sounds good but no outdoor sensors. Visonic Complete/Pro has outdoor sensor, wireless keypad (no wires through stone walls), can partition (new) for gardener to disarm external sensor. Unfortunately, long conversation with Texecom only gives signal advantage but no externals. Had forgotten Risco, but think their keypad also needs to be wired - need to check. Have no real knowledge of Scanny but have a feeling keypad wired. Thanks for the crack. BTW, is there an advantage to being a member? i suppose you want kit that installs itself too!lol
hpotter Posted February 12, 2011 Posted February 12, 2011 Have no real knowledge of Scanny but have a feeling keypad wired. they do a wireless, but cant read log etc so also need wired. BTW, is there an advantage to being a member? debateable
