Gardtec Sensors Reset
pinio
Hi Guys.
I need some help with my alarm.
Recently I did internal wall insulation and I had to remove my detectors, after placing it back they don't want to work, alarm goes off with information that two of them are lost.
I have gardtec panel 800 series with wireless detectors.
Is there any code which would allow me to reset new position of detectors?
There are no instructions how to do it in manual, please help.
Just stay clear for 3 mins then activate them I.e. Get a red light, that's when detector sends s tamper restored signal to panel.
Arfur
Later receivers need updates more often, that csuses detector lost or not ready reports, move dip switch 4 in detector to 'on' to cure it.
Arfur
I wouldnt recommend adjusting any dip switches.
what information exactly are you getting?
Ideally though, the transmitters should be placed back by an alarm engineer and correctly tested as positioning is essential to their operation.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
arf, this would of been the case before he removed them surly?
Agreed, but the report is 'lost' not 'tamper' (not going into an arfurlog ;) ) i'm judt covering both scenarios.
Dip 4 makes reports at intervals compliant with EN, they now come set that way, but many were sent out on old settings. Did not always cause s 'device not ready' report straight away.
Arfur
either it just me or risco radio stuff does not always know the tamper is closed after the sub has tried to move / refit ? (cpx/ 595)
viewing signal strenght appear to cure ?
