Aritech Ats 2000 Battery Terminal Reversed By Accident
Guest hd2000
Greetings
I made a serious noob error, after removing the battery, I absent mindedly put the battery terminal on backwards ;( ;(
I did not power on the panel and quicky fixed the connnection (within like 5 seconds)
The fuse did not blow, the panel is fine except the error 16 (no battery is found)
Can this be easily remedied? Thanx
1st of all check the fuse with a meter. Not just looking at it.
Drop all power and reboot. Should solve it.
Thanx Oxo! I will definitely give this a try!
LOL im back :)
I am one lucky guy for sure! Too lucky!
Fuse did pop, burnt in the far end so I could not see.
Just about to wind up my installation, putting some outdoor beam sensors and I'll be done!
Thanx a mill, this forum rocks!
