sjsturner Posted January 17, 2011 Posted January 17, 2011 hi guys i had some call outs to a site which we took over they have three loops on a zeta panel however they started getting devices come up wrong type?and once they do you cant clear it by re learning or powering down.it starting to become frequent with the smoke detectors.but inside these detectors are apollo!any ideas whats wrong?seems like corrupt data.many thanks in advance
sjsturner Posted January 17, 2011 Author Posted January 17, 2011 Same loop? the first 2were loop relays on loop 2 all the rest have been smokes on loop 3.
Guest Oxo Posted January 17, 2011 Posted January 17, 2011 Earth faults? Sounds like works being done and they have damaged a cable. Ask cerbs, he is the fire Expert here.
sjsturner Posted January 17, 2011 Author Posted January 17, 2011 on loop 3 the earths were never terminated in the panel!but all the others were it was a rushed job by a large firm.and the owner is tight so doesent want the investigation time!could the lack of earth be an issue?
Guest Oxo Posted January 17, 2011 Posted January 17, 2011 Deffinatly. If its cross bonded it could cause several issues. Again Cerbs is the man, but I feel he would agree.
sjsturner Posted January 17, 2011 Author Posted January 17, 2011 cross bonded?could you elaborate on that one for me? i would imagine also as the system was installed by an electrical firm they prob linked fp earth with powes supply earths!see this all the time with sparks
MrHappy Posted January 18, 2011 Posted January 18, 2011 http://www.zetaalarmsystems.com/Fire-Alarm-Systems/ big look to be CEL, smaller one look tat Mr Veritas God
sjsturner Posted January 18, 2011 Author Posted January 18, 2011 http://www.zetaalarmsystems.com/Fire-Alarm-Systems/ thanks for the reply. yea its the premier al4. its a **** panel but very easy to use i learnt it all without any manuals. its only slightly harder to set up loop relays as they dont work even when there learnt on you have to set up the zone and output type which wasent as straight forward as it could be!
